Автор Тема: E34721197  (Прочитано 817 раз)
E34721197
« : 08 Сентября 2016, 09:52:19 »
E34721197
Event ID
E34721197   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
11/15/2007 12:40:09 PM
Subject
No audio or video via HDMI
No audio or video on the TV when used with one of the above sources and connected via HDMI.
[Primary Symptom Code: 118X ]
Solution
Some 2007 models of TV support xvYCC which is a new color space available for some new
television models. When HDMI devices first communicate, an EDID file (Extended display
identification data) is passed from the display to the source device. The source device shall
support variations within the file structure however it was noted that the above source devices
(see attached) have a conflict. The issue must be resolved within the source device.
DO NOT change parts on the TV as it will have no effect.
Supporting Documents
File   Description
HDMI.pdf   Complete Service Bulletin
Model Details
KDL40W3000    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL40XBR4    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL40XBR5    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL46W3000    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL46XBR4    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL46XBR5    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL52W3000    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL52XBR4    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL52XBR5    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL70XBR3    ALL    ALL    INY   4/1/2007   FIXP   40   TV and Display (TVP)
KDL70XBR5    ALL    ALL    STE      FIX2   40   TV and Display (TVP)
KDS50A3000    ALL    ALL    STE   8/1/2007   SP4   40   TV and Display (TVP)
KDS55A3000    ALL    ALL    STE   8/1/2007   SP4   40   TV and Display (TVP)
KDS60A3000    ALL    ALL    STE   8/1/2007   SP4   40   TV and Display (TVP)
