Автор Тема: E34662570  (Прочитано 771 раз)
E34662570
« : 08 Сентября 2016, 09:51:41 »
E34662570
Event ID
E34662570   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
7/10/2007 12:36:25 PM
Subject
Rolling picture
Rolling picture. Seems to be a double image rolling vertically.
Main image is stationary and the ghost is rolling vertically.
OSD is also doing this, on all inputs.
[Primary Symptom Code: 135X ]
Solution
Replacing the BU Board corrected the symptom.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDL40V2500    SEE    SOLUTION    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL46V2500    8035199    8035199    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL46V25L1    SEE    SOLUTION    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1196664A    57   BU Board KDL-46V2500 Only   135X   DPR   BU    A   A
