Автор Тема: E34624958  (Прочитано 758 раз)
E34624958
« : 08 Сентября 2016, 09:50:58 »
E34624958
Event ID
E34624958   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
7/5/2007 7:14:46 PM
Subject
Vertical bar
1 inch wide vertical bar on the right side, change color depending on the scene
[Primary Symptom Code: 1344 ]
Solution
Check LVDS cable and they were OK.
Replaced the Panel and symptom was resolved.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDL23S2010    SEE    SOLUTION    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL26S2010    SEE    SOLUTION    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2010    SEE    SOLUTION    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2010    SEE    SOLUTION    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL46S2010    8045234    8045234    STE   7/1/2006   WAX2   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
180210031    252   Panel KDL46S2010 Only   1344   IMG   NONE    A   A
