Автор Тема: E34621067  (Прочитано 749 раз)
E34621067
« : 08 Сентября 2016, 09:27:08 »
E34621067
Event ID
E34621067   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
7/5/2007 7:19:09 PM
Subject
Dead 6X error
Dead 6X error.
[Primary Symptom Code: 1111 ]
Solution
D of Q6606 has 392V & D of Q6607 has 248V & G has 1.2V
No high voltage.
On the D1 Inverter Board
Checked for 390 vdc between CN6600/ pin 1 and 3 on D1 Board.
Checked CN6707/pins 6 (12v). From CN6204/pin 6 G3 Board.
Checked CN6950/pin13 (12V)
They were OK.
On D2 Inverter Board
Checked for 391vdc between CN6900/ pins 1 and 3.
Checked CN6950/pin 13 (12v) From D1 Board CN6704/pin 13.
Replacing the D2 Board restored operation
See TM E34200874 about removing the Inverter Boards D1 or D2.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDL26S3000    SEE    SOLUTION    STE   4/1/2007   WAX3   40   TV and Display (TVP)
KDL32S3000    SEE    SOLUTION    STE   4/1/2007   WAX3   40   TV and Display (TVP)
KDL46S3000    8008973    8008973    STE   4/1/2007   WAX3   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1247497A    154   D2 Board KDL-46S3000 only   1111   PSU   D2    A   A
