Автор Тема: E34603310  (Прочитано 754 раз)
E34603310
« : 08 Сентября 2016, 09:26:36 »
CONFIDENTIALE34603310
Event ID
E34603310   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
7/3/2007 11:55:46 AM
Subject
No Picture back light on, Green LED on solid
No Picture back light on, Green LED on solid.
Black horizontal lines on screen.
[Primary Symptom Code: 1311 ]
Solution
Found problem to be faulty QM Board.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDL40XBR3    8009317    8009317    STE   8/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR3    SEE    SOLUTION    STE   8/1/2006   FIX   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1212258A    105   QM Board   1311   DPR   QM    A   A
