Автор Тема: E34305549  (Прочитано 719 раз)
E34305549
« : 07 Сентября 2016, 18:02:59 »
E34305549
Event ID
E34305549   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
6/12/2007 11:53:26 AM
Subject
Picture for a moment then 9 blink shutdown
You will see the picture flash for a moment then the set will shutdown with 9 blinks
[Primary Symptom Code: 2311 ]
Solution
This could be caused by the D2 board, D3 board, or the panel
If you observe the picture prior to shutdown you can isolate the problem to the defective part.
Please use the attached service procedure
This is easily seen with a solid test pattern or with the tuner as the source with no signal applies
to the unit.
Supporting Documents
File   Description
FIX-40-46-9blink--flashand9blinks.pdf   Procedure for testing 9 Blinks
Model Details
KDL40XBR2    ALL    ALL    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL40XBR3    ALL    ALL    STE   8/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR2    ALL    ALL    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR3    ALL    ALL    STE   8/1/2006   FIX   40   TV and Display (TVP)
