Автор Тема: E34261227  (Прочитано 734 раз)
E34261227
« : 07 Сентября 2016, 18:02:27 »
E34261227
Event ID
E34261227   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
2/26/2009 1:12:32 PM
Subject
Dark Spot in center after reassembling
After the install of the D2 board, D3 board, or the panel
the picture has a dark strip that runs down the center of the screen.
[Primary Symptom Code: 118X ]
Solution
This is easily seen with a solid test pattern or with the tuner as the source with no signal applied
to the unit.
Check that CN6700 and CN6754 on the D1 board or CN6900 and CN6902 on the D2 board
has not been mistakenly swapped over after replacement of D2 board, D3 board, or the panel.
Supporting Documents
File   Description
dark_center_after_part_replacment.pdf   Picture of symptom
Model Details
KDL40XBR2    ALL    ALL    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL40XBR3    ALL    ALL    STE   8/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR2    ALL    ALL    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR3    ALL    ALL    STE   8/1/2006   FIX   40   TV and Display (TVP)
