Автор Тема: E34200874  (Прочитано 742 раз)
E34200874
« : 07 Сентября 2016, 18:01:53 »
E34200874
Event ID
E34200874   Type
Training Materials    Level
4   Safety Issue
No   AutoFlag
No   Last Update
3/4/2008 6:04:44 PM
Subject
Inverter Board removal caution
[Primary Symptom Code: 118X ]
Solution
Attached is a bulletin regarding inverter replacement for the WAX3 chassis models. The backlight tubes are no longer wired to the boards. A socket is used for each tube and these sockets connect to the backlights along with the inverter board. I believe there is a probability that someone may remove the screws securing the socket array to the back of the panel thinking that this is how the inverter is removed. If this happens one or more of the tubes will break since they are seated tightly into the sockets. This will require a panel replacement. Only the screws securing the inverter cover need to be removed. Once this is done the inverter board is simply pulled out from the socket array.
Supporting Documents
File   Description
InverterWarning.pdf   Warning Bulletin
Model Details
KDL32M3000    ALL    ALL    STE   7/1/2007   MA1   40   TV and Display (TVP)
KDL32S3000    ALL    ALL    SML   4/1/2007   WAX3   40   TV and Display (TVP)
KDL32SL130    ALL    ALL    SML   4/1/2007   WAX3   40   TV and Display (TVP)
KDL32XBR4    ALL    ALL    SML   5/1/2007   WAX3   40   TV and Display (TVP)
KDL37M3000    ALL    ALL    STE   8/1/2007   MA1   40   TV and Display (TVP)
