Автор Тема: E33996384  (Прочитано 746 раз)
E33996384
« : 07 Сентября 2016, 18:01:25 »
E33996384
Event ID
E33996384   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
4/20/2007 2:06:53 PM
Subject
6 Blinks Red LED
Red LED is blinking 6x
[Primary Symptom Code: 2111 ]
Solution
Tech found one of the circuits shorted off pins 9 and 10 CN4004.
Replacing the BE2 and G Board fixed the 6X error.
Suspect the G board went bad when the circuit on the BE2 board shorted.
From the Training Manual CTV-39
6X PFC Detect
The Power Factor Correction circuit on the G 1 board (not shown) generates the 380VDC for
the Lamp Driver board's). If this circuit fails (which will cause the voltage to drop to one-half
the correct level) the normally high voltage sent to pin 137 of IC8002 will go low and the unit
will turn off and display a sequence of 6 blinks on the POWER LED. See Block Diagram below.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Supporting Documents
File   Description
Blockdiagram.pdf   Block Diagram
Model Details
KDL40XBR2    8094371    8094371    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL40XBR3    SEE    SOLUTION    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR2    SEE    SOLUTION    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR3    SEE    SOLUTION    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL52XBR3    SEE    SOLUTION    STE   7/1/2006   FIX   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1217644A    112   G1 Board (KDL40XBR2)   2111   PSU   G1    A   A
A1212256A    103   BE2 Board (KDL40XBR2)   2111   DPR   BE2    Q   A
