Автор Тема: E33862141  (Прочитано 760 раз)
E33862141
« : 07 Сентября 2016, 18:00:48 »
E33862141
Event ID
E33862141   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
4/4/2007 6:48:08 PM
Subject
Poor picture, snowy
Poor picture, snowy picture.
[Primary Symptom Code: 1333 ]
Solution
Replaced Antenna Switch.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDL40XBR2    8045507    8045507    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR2    SEE    SOLUTION    STE   7/1/2006   FIX   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
141771611    106   REPLACED ANT SW   1333   ANT   NONE    A   A
