Автор Тема: E33264902  (Прочитано 746 раз)
E33264902
« : 07 Сентября 2016, 17:28:28 »
E33264902
Event ID
E33264902   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
1/31/2007 3:48:26 PM
Subject
White screen with horizontal and vertical line
Very intermittent unit had no picture only white screen with Horizontal and vertical line.
Tech replaced Panel with Tcon but unit still had the same symptom.
[Primary Symptom Code: 1311 ]
Solution
Found the problem was with the LVDS cable.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Supporting Documents
File   Description
Symptom.JPG   Symptom
connector.JPG   Connector
whitescreensymptom.JPG   Symptom white screen with lines
Model Details
KDL40XBR2    SEE    SOLUTION    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL40XBR3    SEE    SOLUTION    PITT   8/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR2    8052711    8052711    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR3    SEE    SOLUTION    PITT   8/1/2006   FIX   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
183295731    110   LVDS Cable connector KDLXBR2 ONLY   1311   OUT   NONE    A   A
