Автор Тема: E33202721  (Прочитано 775 раз)
E33202721
« : 07 Сентября 2016, 17:27:41 »
E33202721
Event ID
E33202721   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
1/23/2007 1:39:56 PM
Subject
No picture
No picture.
[Primary Symptom Code: 1311 ]
Solution
Replaced IC1005 on the BU Board.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDL23S2010    4002075    4002075    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL26S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL46S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
671012101    IC1005   IC M24256-BWMN6TP(A)   1311   SYS   BU    A   A
