Автор Тема: E33201052  (Прочитано 773 раз)
E33201052
« : 07 Сентября 2016, 17:27:14 »
E33201052
Event ID
E33201052   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
1/31/2007 6:41:48 PM
Subject
Analog channel only channel 2 shows INTERNAL
On Analog channel only channel 2 shows the rest stay hiding, Can't use the channel up or down. Tech did auto program but seems like channel 1-25 the rest are hiding. When he auto programs doing this process he sees all the channels.
Using RF cable input and no STB required
[Primary Symptom Code: 1214 ]
Solution
Tried replacing the QS and BU Boards, but still the same.
Changing the AU Board and did the audio program again. Now it showed the hidden
channels and can be tuned in.
HQ Comments: Don't see how the A/V switching and Audio circuits can cause this unless the Data/clock was loaded down. Therefore I placed it under internal.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDLV32XBR2    8024284    8024284    STE   8/1/2006   WAX2   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1192415D    58   AU Board   1214   APR   AU    A   A
