Автор Тема: E33166803  (Прочитано 869 раз)
E33166803
« : 07 Сентября 2016, 17:26:42 »
E33166803
Event ID
E33166803   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
11/13/2007 12:39:26 PM
Subject
Shut down 4X blinking or half the screen is not lit. (Panel inverter board part numbers)
Rather than changing the entire LCD panel assembly can we change the inverter board?
[Primary Symptom Code: 118X ]
Solution
Yes, please follow the matrix below for the correct part numbers.
KDL26S2000 and KDL26S2010 and KDL26S20L1
PART NUMBER: 178950711
KDL32S2000 and KDL32S2400 and KDL32S20L1 and KDL32S2010
PART NUMBER: 178950411
KDL40S2000 and KDL40V2500 and KDL40S2400 and KDL40S20L1 and KDL40S2010
PART NUMBER: 178950011
NOTE: 2 spacers, part number 2-897-655-01 are required. See attached for details within
the 40 inch section of the pdf file.
KDL46S2000 and KDL46V2500 and KDL46V25L1 and KDL46S2010
PART NUMBER: A1251295B
NOTE: Troubleshooting tips.
For the 32 inch models there are 3 yellow fuses located on the inverter board (F001, F002, and
F003). Quite often F003 will be opened when an inverter board fails so please check this fuse
with your meter.
For the 40 inch models there are 3 yellow fuses located on the inverter board (F001, F002, and F003). Check these fuses first. F002 or F003 may be opened when an inverter board fails.
This is a good starting point.
Symptoms of an inverter board problem.
The picture may come on with half of the screen being darker than the rest.
The TV may come on but have no backlight.
The TV may shutdown and the front panel LED blinks 4 times.
Supporting Documents
File   Description
E33166803r7.pdf   Inverter Board troubleshooting tips
DSC00010.JPG   Spacer 289765501
Model Details
KDL26S2000    ALL    ALL    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL26S2010    ALL    ALL    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL26S20L1    ALL    ALL    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2000    ALL    ALL    SML   5/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2010    ALL    ALL    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL32S20L1    ALL    ALL    SML   5/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2400    ALL    ALL    SML   9/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2000    ALL    ALL    SML   5/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2010    ALL    ALL    SML   4/1/2006   WAX2   40   TV and Display (TVP)
KDL40S20L1    ALL    ALL    SML   5/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2400    ALL    ALL    SML   9/1/2006   WAX2   40   TV and Display (TVP)
KDL40V2500    ALL    ALL    SML   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL46S2000    ALL    ALL    SML   5/1/2006   WAX2   40   TV and Display (TVP)
KDL46S2010    ALL    ALL    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL46V2500    ALL    ALL    SML   9/1/2006   WAX2   40   TV and Display (TVP)
KDL46V25L1    ALL    ALL    SML   9/1/2006   WAX2   40   TV and Display (TVP)
