Автор Тема: E33162922  (Прочитано 790 раз)
E33162922
« : 07 Сентября 2016, 17:26:07 »
E33162922
Event ID
E33162922   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
1/22/2007 11:16:43 AM
Subject
No color RF or composite
No color on RF or composite inputs. Component is OK.
[Primary Symptom Code: 1411 ]
Solution
Replacing the BU Board resolved the no color symptom.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDL40V2500    SEE    SOLUTION    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL46V2500    8005534    8005534    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL46V25L1    SEE    SOLUTION    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1196664A    57   BU Board (KDL46V2500 ONLY)   4111   CPA   BU    A   A
