Автор Тема: E33140194  (Прочитано 796 раз)
E33140194
« : 07 Сентября 2016, 17:25:31 »
E33140194
Event ID
E33140194   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
1/17/2007 2:06:59 PM
Subject
No power
Power never comes on. Green LED may light or blink.
Relay may be heard to click.
[Primary Symptom Code: 1111 ]
Solution
Found D5V at connector CN9502 pin-3 reads 2.4 volts.
Replaced BU Board.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDL23S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL26S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2010    4018345    4018345    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL46S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1179492A    63   BU Board (KDL32S2010 only)   1111   APR   BU    A   A
