Автор Тема: E33126162  (Прочитано 736 раз)
E33126162
« : 07 Сентября 2016, 17:25:02 »
E33126162
Event ID
E33126162   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
1/16/2007 12:14:17 PM
Subject
Intermittent remote operation
Intermittent remote operation.
Channels change on their own sometimes.
[Primary Symptom Code: 2151 ]
Solution
Replaced Q8214 on the AL Board.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDLV26XBR1    SEE    SOLUTION    STE   2/1/2006   MIX5   40   TV and Display (TVP)
KDLV32XBR1    SEE    SOLUTION    STE   2/1/2006   MIX5   40   TV and Display (TVP)
KDLV40XBR1    8039664    8039664    STE   2/1/2006   MIX5   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
655058601    Q8214   2PA1576R-115   2151   REM   AL    A   A
