Автор Тема: E33087561  (Прочитано 681 раз)
E33087561
« : 07 Сентября 2016, 17:24:24 »
E33087561
Event ID
E33087561   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
1/19/2007 1:19:00 PM
Subject
Connector part numbers
[Primary Symptom Code: 118X ]
Solution
The correct P/N for the 2-conductor cable that connects CN6700 on the D1 board to CN6800
on the LCD driver board is 191002609 BD Connector Assy (Blk) 2P.
This is the short HV wire.
Please see attached file for reference of P/N and model for each HV wire.
Supporting Documents
File   Description
HVwiresPN.pdf   Connect harnes part number
Model Details
KDL40XBR3    ALL    ALL    STE   8/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR3    ALL    ALL    STE   8/1/2006   FIX   40   TV and Display (TVP)
