Автор Тема: E32977246  (Прочитано 665 раз)
E32977246
« : 07 Сентября 2016, 17:03:18 »
E32977246
Event ID
E32977246   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
1/2/2007 2:58:02 PM
Subject
No tuning
No tuning, finds no channels during channel setup.
[Primary Symptom Code: 121X ]
Solution
Bottom cable, CN7803 QT Board, was unplugged. Other end to CN7501 AU Board.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Supporting Documents
File   Description
CN7803.JPG   CN7803 connector
Model Details
KDL23S2010    4007611    4007611    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL26S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL46S2010    AEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
