Автор Тема: E32923079  (Прочитано 707 раз)
E32923079
« : 07 Сентября 2016, 17:02:22 »
E32923079
Event ID
E32923079   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
10/8/2009 2:16:44 PM
Subject
Infrared interference from CCFL
Infrared interference from CCFL.
Remote may not work correctly immediately after power on.
May affect the TV, DVD/BluRay, or cable box etc...
[Primary Symptom Code: 118X ]
Solution
See attached. NOTE: You only need to place one (1) filter over the IR sensor.
The attached tech memo makes it sounds like you need both but only one (1) is fine.
Supporting Documents
File   Description
E32923079.pdf   Service Bulletin
Model Details
KDL19M4000    ALL    ALL    STE            TV and Display (TVP)
KDL26M4000    ALL    ALL    STE            TV and Display (TVP)
KDL26N4000    ALL    ALL    STE            TV and Display (TVP)
KDL26NL140    ALL    ALL    STE            TV and Display (TVP)
KDL32M4000    ALL    ALL    STE            TV and Display (TVP)
KDL32N4000    ALL    ALL    STE            TV and Display (TVP)
KDL32NL140    ALL    ALL    STE            TV and Display (TVP)
KDL32VL140    ALL    ALL    STE            TV and Display (TVP)
KDL32XBR6    ALL    ALL    STE            TV and Display (TVP)
KDL37N4000    ALL    ALL    STE            TV and Display (TVP)
KDL37NL140    ALL    ALL    STE            TV and Display (TVP)
KDL37XBR6    ALL    ALL    STE            TV and Display (TVP)
KDL40M4000    ALL    ALL    STE            TV and Display (TVP)
KDL40S2000    ALL    ALL    STE            TV and Display (TVP)
KDL40S20L1    ALL    ALL    STE            TV and Display (TVP)
KDL40S4100    ALL    ALL    STE            TV and Display (TVP)
KDL40SL140    ALL    ALL    STE            TV and Display (TVP)
KDL40V2000    ALL    ALL    STE            TV and Display (TVP)
KDL40V4100    ALL    ALL    STE            TV and Display (TVP)
KDL40V4150    ALL    ALL    STE            TV and Display (TVP)
KDL40W4100    ALL    ALL    STE            TV and Display (TVP)
KDL40WL140    ALL    ALL    STE            TV and Display (TVP)
KDL40XBR6    ALL    ALL    STE            TV and Display (TVP)
KDL40XBR7    ALL    ALL    STE            TV and Display (TVP)
KDL40Z4100    ALL    ALL    STE            TV and Display (TVP)
KDL42V4100    ALL    ALL    STE            TV and Display (TVP)
KDL46S2000    ALL    ALL    STE            TV and Display (TVP)
KDL46SL140    ALL    ALL    STE            TV and Display (TVP)
KDL46V2000    ALL    ALL    STE            TV and Display (TVP)
KDL46V4100    ALL    ALL    STE            TV and Display (TVP)
KDL46W4100    ALL    ALL    STE            TV and Display (TVP)
KDL46W4150    ALL    ALL    STE            TV and Display (TVP)
KDL46WL140    ALL    ALL    STE            TV and Display (TVP)
KDL46XBR6    ALL    ALL    STE            TV and Display (TVP)
KDL46XBR8    ALL    ALL    STE            TV and Display (TVP)
KDL46Z4100    ALL    ALL    STE            TV and Display (TVP)
KDL52S4100    ALL    ALL    STE            TV and Display (TVP)
KDL52V4100    ALL    ALL    STE            TV and Display (TVP)
KDL52W4100    ALL    ALL    STE            TV and Display (TVP)
KDL52WL140    ALL    ALL    STE            TV and Display (TVP)
KDL52XBR6    ALL    ALL    STE            TV and Display (TVP)
KDL55XBR8    ALL    ALL    STE            TV and Display (TVP)
KDL70XBR7    ALL    ALL    STE            TV and Display (TVP)
