Автор Тема: E32817941  (Прочитано 766 раз)
E32817941
« : 07 Сентября 2016, 17:00:43 »
E32817941
Event ID
E32817941   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
12/15/2006 6:54:43 PM
Subject
No remote function after turn on
It takes 1 minute for picture to come on, but after picture appears the remote will not allow any
other function. Such as changing channels. No failure codes comes up. On the Video 2 input
can see picture if video is inputed, but no audio.
[Primary Symptom Code: 1161 ]
Solution
Replacing the QM Board, resolved the issue.
Note: Data/Clock line was being loaded down by this board. Any board connected to the
Data/Clock line could also cause this symptom.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDL40XBR2    8014270    8014270    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR2    SEE    SOLUTION    STE   7/1/2006   FIX   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1212258A    105   QM   1161   TUN   QM    A   A
