Автор Тема: E32796434  (Прочитано 720 раз)
E32796434
« : 07 Сентября 2016, 16:59:52 »
E32796434
Event ID
E32796434   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
12/15/2006 12:21:24 PM
Subject
No audio
No audio.
[Primary Symptom Code: 1510 ]
Solution
Tech found CN9001 on AU Board was not secured well
Reseated the connector to restore audio.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDL40V2500    8040818    8040818    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL46V2500    SEE    SOLUTION    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL46V25L1    SEE    SOLUTION    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
