Автор Тема: E32576189  (Прочитано 695 раз)
E32576189
« : 07 Сентября 2016, 16:57:52 »
E32576189
Event ID
E32576189   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
11/21/2006 8:07:28 PM
Subject
No Intermittent, or Distorteded picture symptoms
No Intermittent, or Distorteded picture symptoms:
[Primary Symptom Code: 1311 ]
Solution
1. Symptom: Intermittent no picture, but sound is OK.
SOLUTION: Replaced BU Board
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Model Details
KDL26S2000    SEE    SOLUTION    INY   2/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2000    SEE    SOLUTION    INY   2/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2000    SEE    SOLUTION    INY   2/1/2006   WAX2   40   TV and Display (TVP)
