Автор Тема: E32570626  (Прочитано 716 раз)
E32570626
« : 07 Сентября 2016, 16:54:45 »
E32570626
Event ID
E32570626   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
12/10/2007 2:10:52 PM
Subject
No picture
No picture.
[Primary Symptom Code: 1311 ]
Solution
1. No Picture
Found CN-7802 loose
QT Board CN-7800- QM Board CN-7802 49 pins
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Model Details
KDL40XBR3    SEE    SOLUTION    STE   8/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR3    8047449    8047449    STE   8/1/2006   FIX   40   TV and Display (TVP)
