Автор Тема: E32544568  (Прочитано 668 раз)
E32544568
« : 07 Сентября 2016, 16:52:33 »
E32544568
Event ID
E32544568   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
11/17/2006 7:03:00 PM
Subject
Can not tune in all digital channels
Customer complained that her set only picked up 3 Digital stations using antenna over air
broadcast, and using the Digital Auto tune..
The other sets in her home pick up 13 Digital Channels.
[Primary Symptom Code: 121X ]
Solution
Had the customer go into the Diagnostic menu (See O/M page 39).
From that screen I realized she only picked up stations below channel 13.
I then surmised she must have the tuner set to cable since the antenna channel frequencies
and cable channel frequencies above channel 13 are different.
I had her go into the customer menu and turn cable OFF. See O/M page 34.
After redoing the Digital Auto tune (See O/M page 38) all 13 channels were available.
Supporting Documents
File   Description
OwnersManual.pdf   Owners Manual
Model Details
KDL23S2010    ALL    ALL    STE   6/1/2006   WAX2   40   TV and Display (TVP)
KDL26S2010    ALL    ALL    STE   6/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2010    ALL    ALL    STE   6/1/2002   WAX2   40   TV and Display (TVP)
KDL40S2010    ALL    ALL    STE   6/1/2002   WAX2   40   TV and Display (TVP)
KDL46S2010    ALL    ALL    STE   6/1/2006   WAX2   40   TV and Display (TVP)
