Автор Тема: E32544311  (Прочитано 698 раз)
E32544311
« : 07 Сентября 2016, 16:51:43 »
E32544311
Event ID
E32544311   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
11/17/2006 6:16:32 PM
Subject
Safety strap part number
What is the P/N for the safety strap between the Stand and TV?
[Primary Symptom Code: 118X ]
Solution
The P/N is listed in the back of the S/M listed as Bag Assy Rudder.
This contains the Strap (Lock Assy Rudder, and the screws.
Supporting Documents
File   Description
safetystrap.pdf   Safety strap
Model Details
KDL40XBR2    ALL    ALL    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR2    ALL    ALL    STE   7/1/2006   FIX   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
X21025112    NONE   Bag Assy Rudder   118X   XXX   NONE    Z   A
