Автор Тема: E32512923  (Прочитано 779 раз)
E32512923
« : 07 Сентября 2016, 16:50:46 »
E32512923
Event ID
E32512923   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
11/17/2006 3:55:20 PM
Subject
Picture too big for screen
Picture too tall or too big for screen.
[Primary Symptom Code: 1336 ]
Solution
Customer using Satellite TV box which was set too Zoom mode.
Changing mode on box restored normal operation.
NOTE: Cable boxes to can be set to output certain formats only. This can cause the picture to be too small or too big to fit the screen size. Check if the other inputs are having the same symptom, if not check the output settings on the signal source of symptom.
Model Details
KD27FS170    SEE    SOLUTION    STE   2/1/2006   BA6   40   TV and Display (TVP)
KD32FS130    SEE    SOLUTION    STE   6/1/2005   BA6   40   TV and Display (TVP)
KD32FS170    SEE    SOLUTION    STE   2/1/2006   BA6   40   TV and Display (TVP)
KD36FS130    SEE    SOLUTION    STE   6/1/2005   BA6   40   TV and Display (TVP)
KD36FS170    SEE    SOLUTION    STE   2/1/2006   BA6   40   TV and Display (TVP)
KDF42E2000    SEE    SOLUTION    STE   8/1/2006   LA4   40   TV and Display (TVP)
KDF46E2000    SEE    SOLUTION    STE   5/1/2006   LA4   40   TV and Display (TVP)
KDF50E2000    SEE    SOLUTION    STE   5/1/2006   LA4   40   TV and Display (TVP)
KDF55E2000    8026130    8026130    STE   5/1/2006   LA4   40   TV and Display (TVP)
KDL23S2000    SEE    SOLUTION    STE   3/1/2006   WAX2   40   TV and Display (TVP)
KDL23S2010    SEE    SOLUTION    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL26S2000    SEE    SOLUTION    STE   3/1/2006   WAX2   40   TV and Display (TVP)
KDL26S2010    SEE    SOLUTION    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL26S20L1    SEE    SOLUTION    STE   5/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2000    ALL    ALL    STE   3/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2010    SEE    SOLUTION    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL32S20L1    SEE    SOLUTION    STE   5/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2400    SEE    SOLUTION    STE   9/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2000    SEE    SOLUTION    STE   3/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2010    SEE    SOLUTION    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL40S20L1    SEE    SOLUTION    STE   5/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2400    SEE    SOLUTION    STE   9/1/2006   WAX2   40   TV and Display (TVP)
KDL40V2500    SEE    SOLUTION    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL40XBR2    SEE    SOLUTION    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL40XBR3    SEE    SOLUTION    STE   8/1/2006   FIX   40   TV and Display (TVP)
KDL46S2000    ALL    ALL    STE   4/1/2006   WAX2   40   TV and Display (TVP)
KDL46S2010    SEE    SOLUTION    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL46S20L1    SEE    SOLUTION    STE   5/1/2006   WAX2   40   TV and Display (TVP)
KDL46V2500    SEE    SOLUTION    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL46V25L1    SEE    SOLUTION    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL46XBR2    SEE    SOLUTION    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR3    SEE    SOLUTION    STE   8/1/2006   FIX   40   TV and Display (TVP)
KDL52XBR2    SEE    SOLUTION    STE   10/1/2006   FIX   40   TV and Display (TVP)
KDL52XBR3    SEE    SOLUTION    STE   10/1/2006   FIX   40   TV and Display (TVP)
KDLV32XBR2    SEE    SOLUTION    STE   8/1/2006   WAX2   40   TV and Display (TVP)
KDP57WV710    SEE    SOLUTION    STE      AX1   40   TV and Display (TVP)
KDP65WV710    SEE    SOLUTION    STE      AX1   40   TV and Display (TVP)
KDS50A2000    SEE    SOLUTION    STE   6/1/2006   SP3   40   TV and Display (TVP)
KDS55A2000    SEE    SOLUTION    STE   6/1/2006   SP3   40   TV and Display (TVP)
KDS60A2000    SEE    SOLUTION    STE   6/1/2006   SP3   40   TV and Display (TVP)
KDX46Q005    SEE    SOLUTION    STE   12/1/2006   MR3   40   TV and Display (TVP)
KLVS26A10    SEE    SOLUTION    STE   3/1/2006   WAX2   40   TV and Display (TVP)
KLVS32A10    SEE    SOLUTION    STE   3/1/2006   WAX2   40   TV and Display (TVP)
KLVS40A10    SEE    SOLUTION    STE   3/1/2006   WAX2   40   TV and Display (TVP)
