Автор Тема: E32450457  (Прочитано 680 раз)
E32450457
« : 07 Сентября 2016, 16:48:51 »
E32450457
Event ID
E32450457   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
11/6/2006 6:27:17 PM
Subject
White raster, no remote or menu
White raster, no remote or menu.
Turn set on at the set only it comes up on channel 11 and then goes completely white, no menu on the set or remote function, Power LED keeps blinking. Set apparently is in aging mode.
Can't access service menu.
[Primary Symptom Code: 1311 ]
Solution
Replaced BU Board A1179493A.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number. Please refer to the S/M and check for Service Bulletins before ordering any part.
Model Details
KDL32S2000    SEE    SOLUTION    INY   5/1/2006   WAX   40   TV and Display (TVP)
KDL32S20L1    SEE    SOLUTION    INY   5/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2000    SEE    SOLUTION    INY   5/1/2006   WAX   40   TV and Display (TVP)
KDL40S20L1    8016616    8016616    INY   5/1/2006   WAX2   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1179493A    65   BU Board (KDL40S20L1)   1311   OUT   BU    A   A
