Автор Тема: E32343174  (Прочитано 667 раз)
E32343174
« : 07 Сентября 2016, 16:47:47 »
E32343174
Event ID
E32343174   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
12/15/2006 4:58:22 PM
Subject
Ghosting on component inputs
Light ghosting around images from satalite local channels supplied through component input.
If input signal from DVD on component inputs picture was fine
[Primary Symptom Code: 1346 ]
Solution
Found the satellite box was hooked up to composite inputs and RF to TV input. Channel 3 which was 480i out of satellite box.
Hooked up satellite box to component input on back of unit ( instead of side where satellite guy installed it) and put input to component in and formatted box to OUTPUT 1080i and ghosting was eliminated and looked good.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Model Details
KDLV26XBR1    SEE    SOLUTION    STE   2/1/2006   MIX5   40   TV and Display (TVP)
KDLV32XBR1    SEE    SOLUTION    STE   2/1/2006   MIX5   40   TV and Display (TVP)
KDLV40XBR1    8120115    8120115    STE   2/1/2006   MIX5   40   TV and Display (TVP)
