Автор Тема: E32164713  (Прочитано 727 раз)
E32164713
« : 07 Сентября 2016, 16:25:55 »
E32164713
Event ID
E32164713   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
10/3/2006 11:14:06 AM
Subject
No red green too strong
No red color, green too strong. Found BE2 Board defective.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
[Primary Symptom Code: 1431 ]
Solution
Please consult a technical representative...
Model Details
KDL40XBR2    SEE    SOLUTION    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR2    ALL    ALL    STE   7/1/2006   FIX   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1212544A    103   BE2 Board   1431   DPR   BE2    A   A
