Автор Тема: E32164574  (Прочитано 775 раз)
E32164574
« : 07 Сентября 2016, 16:25:05 »
E32164574
Event ID
E32164574   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
3/28/2007 4:51:11 PM
Subject
Dead set
Dead set, No power.
[Primary Symptom Code: 1111 ]
Solution
1. Dead set
Found F6000 on the G1 Board was open.
2. Dead Set:
Found BE2 Board defective.
3. Model: KDL40XBR2 Ser: 8101041
Symptom: Dead, green LED does come on. Back light is on. No video, OSD, or Audio.
There is orange LED flashing toward the middle of the set which is on the BE2 Board.
The remote turns TV on and Off same with front buttons but no other functions.
Solution: Replacing the QM Board resolved the issue.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Model Details
KDL40XBR2    8012638    8012638    STE   7/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR2    SEE    SOLUTION    STE   7/1/2006   FIX   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
157623312    F6000   6.3 amp fuse   1111   PSU   G1    R   A
A1212544A    103   BE2 Board   1111   DPR   BE2    A   A
A1212258A    105   QM Board   1111   TUN   QM    A
