Автор Тема: E32066805  (Прочитано 627 раз)
E32066805
« : 07 Сентября 2016, 16:20:27 »
E32066805
Event ID
E32066805   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
9/20/2006 2:08:33 PM
Subject
No digital audio analog is ok
No digital audio, analog is ok.
When using off the air it has no sound on any ATSC channels but analog are fine.
[Primary Symptom Code: 1510 ]
Solution
No audio using the ATSC tuner, tried the Optical Output to a stereo and it works.
No sound on the set itself in ATSC mode, works OK in NTSC
Found CN7502 to AU Board wires slightly pulled out of the connector.
Reinserted wires into connector and unit is now functioning normally.
Supporting Documents
File   Description
CN7502.JPG   CN7502
Model Details
KDL23S2010    4001888    4001888    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL26S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
KDL46S2010    SEE    SOLUTION    SML   7/1/2006   WAX2   40   TV and Display (TVP)
