Автор Тема: E31992346  (Прочитано 700 раз)
E31992346
« : 07 Сентября 2016, 16:19:41 »
E31992346
Event ID
E31992346   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
9/11/2006 6:44:29 PM
Subject
Panel serial number label
Where on the Panel label is the serial number located?
[Primary Symptom Code: 118X ]
Solution
See the Panel label attached below.
Supporting Documents
File   Description
Panelsernumber.pdf   Label
Model Details
KDL26S2000    SEE    SOLUTION    INY   2/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2000    7006862    7006862    INY   2/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2000    SEE    SOLUTION    INY   2/1/2006   WAX2   40   TV and Display (TVP)
