Автор Тема: E31886601  (Прочитано 723 раз)
E31886601
« : 07 Сентября 2016, 16:18:01 »
Event ID
E31886601   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
9/29/2006 3:49:36 PM
Subject
BU Board part number
What is the correct part number for the BU Board?
[Primary Symptom Code: 118X ]
Solution
Please note that the part number of the BU board is different for each screen size.
Please make sure that you are using the correct part number.
KDL-26S2000 A1179491A
KDL-32S2000 A1179492A
KDL-40S2000 A1179493A
Model Details
KDL26S2000    SEE    SOLUTION    STE   2/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2000    SEE    SOLUTION    STE   2/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2000    SEE    SOLUTION    STE   2/1/2006   WAX2   40   TV and Display (TVP)
