Автор Тема: E31835768  (Прочитано 668 раз)
E31835768
« : 07 Сентября 2016, 15:36:12 »
E31835768
Event ID
E31835768   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
6/12/2007 6:47:03 PM
Subject
Encryption key parts
[Primary Symptom Code: 118X ]
Solution
See Service Bulletin attached below.
The Key Encryption parts in the models listed attached below are not designated in the service manual, therefore, please use the list to determine what boards have Key Encryption devices.
Supporting Documents
File   Description
E31835768.pdf   Service Bulletin Encryption Key Parts
Keyboards.pdf   Encryption key Parts List
Model Details
KD30XS955    ALL    ALL    STE   7/1/2004   DA4   40   TV and Display (TVP)
KD32XS945    ALL    ALL    SML   5/1/2005   DA4   40   TV and Display (TVP)
KD34XBR960    ALL    ALL    STE   6/1/2004   DA4   40   TV and Display (TVP)
KD34XS955    ALL    ALL    SML   7/1/2004   DA4   40   TV and Display (TVP)
KD36XS955    ALL    ALL    STE   8/1/2004   DA4   40   TV and Display (TVP)
KDE37XS955    ALL    ALL    PITT   9/1/2006   XS2   40   TV and Display (TVP)
KDE42XBR950    ALL    ALL    PITT   12/1/2003   MR2   40   TV and Display (TVP)
KDE42XS955    ALL    ALL    PITT   9/1/2004   XS2   40   TV and Display (TVP)
KDE50XBR950    ALL    ALL    PITT   12/1/2003   MR2   40   TV and Display (TVP)
KDE50XS955    ALL    ALL    PITT   9/1/2004   XS2   40   TV and Display (TVP)
KDE55XBR950    ALL    ALL    PITT   7/1/2004   MR2   40   TV and Display (TVP)
KDE61XBR950    ALL    ALL    PITT   12/1/2003   MR2   40   TV and Display (TVP)
KDF42E2000    ALL    ALL    PITT   8/1/2006   LA4   40   TV and Display (TVP)
KDF42WE655    ALL    ALL    PITT   9/1/2004   LA3   40   TV and Display (TVP)
KDF46E2000    ALL    ALL    STE   5/1/2006   LA4   40   TV and Display (TVP)
KDF50E2000    ALL    ALL    STE   5/1/2006   LA4   40   TV and Display (TVP)
KDF50WE655    ALL    ALL    PITT   9/1/2004   LA3   40   TV and Display (TVP)
KDF55E2000    ALL    ALL    STE   5/1/2006   LA4   40   TV and Display (TVP)
KDF55WF655    ALL    ALL    PITT   9/1/2004   LA3   40   TV and Display (TVP)
KDF55XS955    ALL    ALL    PITT   9/1/2004   LA3   40   TV and Display (TVP)
KDF60WF655    ALL    ALL    PITT   9/1/2004   LA3   40   TV and Display (TVP)
KDF60XBR950    ALL    ALL    PITT   10/1/2003   LA2A   40   TV and Display (TVP)
KDF60XS955    ALL    ALL    PITT   9/1/2004   LA3   40   TV and Display (TVP)
KDF70XBR950    ALL    ALL    PITT   10/1/2003   LA2A   40   TV and Display (TVP)
KDFE42A10    ALL    ALL    PITT   10/1/2005   MIX5   40   TV and Display (TVP)
KDFE50A10    ALL    ALL    PITT   10/1/2005   MIX5   40   TV and Display (TVP)
KDFE55A20    ALL    ALL    PITT   6/1/2005   LA3   40   TV and Display (TVP)
KDFE60A20    ALL    ALL    PITT   6/1/2005   LA3   40   TV and Display (TVP)
KDL23S2000    ALL    ALL    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL23S2010    ALL    ALL    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL26S2000    ALL    ALL    STE   3/1/2006   WAX2   40   TV and Display (TVP)
KDL26S2010    ALL    ALL    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL26S20L1    ALL    ALL    STE   5/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2000    ALL    ALL    STE   2/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2010    ALL    ALL    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL32S20L1    ALL    ALL    STE   5/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2400    ALL    ALL    STE   9/1/2006   WAX2   40   TV and Display (TVP)
KDL32S3000    SEE    SOLUTION    PITT   5/1/2020   WAX3   40   TV and Display (TVP)
KDL32XBR4    ALL    ALL    PITT   5/1/2007   WAX3   40   TV and Display (TVP)
KDL32XBR950    ALL    ALL    INY   12/1/2003   NONE   40   TV and Display (TVP)
KDL40D3000    SEE    SOLUTION    PITT   5/1/2007   WAX3   40   TV and Display (TVP)
KDL40S2000    ALL    ALL    STE   3/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2010    ALL    ALL    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL40S20L1    ALL    ALL    STE   5/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2400    ALL    ALL    STE   9/1/2006   WAX2   40   TV and Display (TVP)
KDL40S3000    SEE    SOLUTION    PITT   5/1/2007   WAX3   40   TV and Display (TVP)
KDL40V2500    ALL    ALL    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL40XBR2    ALL    ALL    PITT   7/1/2006   FIX   40   TV and Display (TVP)
KDL40XBR3    ALL    ALL    PITT   8/1/2006   FIX   40   TV and Display (TVP)
KDL42XBR950    ALL    ALL    INY   12/1/2003   NONE   40   TV and Display (TVP)
KDL46S2000    ALL    ALL    STE   4/1/2006   WAX2   40   TV and Display (TVP)
KDL46S2010    ALL    ALL    STE   7/1/2006   WAX2   40   TV and Display (TVP)
KDL46S20L1    ALL    ALL    STE   5/1/2006   WAX2   40   TV and Display (TVP)
KDL46S3000    SEE    SOLUTION    PITT   5/1/2007   WAX3   40   TV and Display (TVP)
KDL46V2500    ALL    ALL    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL46V25L1    ALL    ALL    STE   9/1/2006   WAX2F   40   TV and Display (TVP)
KDL46XBR2    ALL    ALL    PITT   7/1/2006   FIX   40   TV and Display (TVP)
KDL46XBR3    ALL    ALL    PITT   8/1/2006   FIX   40   TV and Display (TVP)
KDL52XBR2    ALL    ALL    PITT   10/1/2006   FIX   40   TV and Display (TVP)
KDL52XBR3    ALL    ALL    PITT   10/1/2006   FIX   40   TV and Display (TVP)
KDLV32XBR1    ALL    ALL    PITT   12/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR2    ALL    ALL    STE   8/1/2006   WAX2   40   TV and Display (TVP)
KDLV40XBR1    ALL    ALL    PITT   12/1/2005   MIX5   40   TV and Display (TVP)
KDP51WS550    ALL    ALL    PITT   7/1/2003   AX1   40   TV and Display (TVP)
KDP51WS655    ALL    ALL    PITT   6/1/2004   AX1   40   TV and Display (TVP)
KDP57WS550    ALL    ALL    PITT   7/1/2003   AX1   40   TV and Display (TVP)
KDP57WV710    ALL    ALL    PITT      AX1   40   TV and Display (TVP)
KDP65WS550    ALL    ALL    PITT   7/1/2003   AX1   40   TV and Display (TVP)
KDP65WV710    ALL    ALL    PITT      AX1   40   TV and Display (TVP)
KDS50A2000    ALL    ALL    PITT   6/1/2006   SP3   40   TV and Display (TVP)
KDS50A2020    ALL    ALL    PITT      XS2   40   TV and Display (TVP)
KDS55A2000    ALL    ALL    PITT   6/1/2006   SP3   40   TV and Display (TVP)
KDS55A2020    ALL    ALL    PITT      XS2   40   TV and Display (TVP)
KDS60A2000    ALL    ALL    PITT   6/1/2006   SP3   40   TV and Display (TVP)
KDS60A2020    ALL    ALL    PITT      XS2   40   TV and Display (TVP)
KDSR50XBR1    ALL    ALL    PITT   8/1/2005   SP1   40   TV and Display (TVP)
KDSR60XBR1    ALL    ALL    PITT      SP1   40   TV and Display (TVP)
KDX46Q005    ALL    ALL    INY   12/1/2006   MR3   40   TV and Display (TVP)
KE37XS910    ALL    ALL    INY   12/1/2003   AT2   40   TV and Display (TVP)
KE42M1    ALL    ALL    PITT   6/1/2004   AT2   40   TV and Display (TVP)
KE42XBR900    ALL    ALL    PITT   11/1/2002   MR1   40   TV and Display (TVP)
KE42XS910    ALL    ALL    INY   12/1/2003   AT2   40   TV and Display (TVP)
KE50XBR900    ALL    ALL    PITT   12/1/2002   MR1   40   TV and Display (TVP)
KE50XS910    ALL    ALL    INY   12/1/2003   AT2   40   TV and Display (TVP)
KF42WE610    ALL    ALL    PITT   10/1/2003   LA2   40   TV and Display (TVP)
KF42WE620    ALL    ALL    PITT   7/1/2004   LA2   40   TV and Display (TVP)
KF50WE610    ALL    ALL    PITT   10/1/2003   LA2   40   TV and Display (TVP)
KF50WE620    ALL    ALL    PITT   7/1/2004   LA2   40   TV and Display (TVP)
KF50XBR800    ALL    ALL    PITT   10/1/2002   LA1   40   TV and Display (TVP)
KF60WE610    ALL    ALL    PITT   10/1/2003   LA2   40   TV and Display (TVP)
KF60XBR800    ALL    ALL    PITT   10/1/2002   LA1   40   TV and Display (TVP)
KLV26HG2    ALL    ALL    INY   12/1/2003   AT2   40   TV and Display (TVP)
KLV30XBR900    ALL    ALL    PITT   1/1/2003   NONE   40   TV and Display (TVP)
KLV32M1    ALL    ALL    PITT   7/1/2004   AT2   40   TV and Display (TVP)
KLV32U100M    ALL    ALL    PITT   1/1/2006   WAVE   40   TV and Display (TVP)
KLV40U100M    ALL    ALL    INY   1/1/2006   WAVE   40   TV and Display (TVP)
KLVS19A10    ALL    ALL    STE   12/1/2005   WAX   40   TV and Display (TVP)
KLVS23A10    ALL    ALL    STE   12/1/2005   WAX   40   TV and Display (TVP)
KLVS26A10    ALL    ALL    STE   3/1/2006   WAX   40   TV and Display (TVP)
KLVS32A10    ALL    ALL    STE   3/1/2006   WAX   40   TV and Display (TVP)
KLVS40A10    ALL    ALL    STE   3/1/2006   WAX   40   TV and Display (TVP)
KP46WT500    ALL    ALL    PITT   10/1/2002   RA6   40   TV and Display (TVP)
KP46WT510    ALL    ALL    STE   6/1/2003   RA6A   40   TV and Display (TVP)
KP46WT520    ALL    ALL    PITT   7/1/2004   AX1X   40   TV and Display (TVP)
KP51WS500    ALL    ALL    PITT      080102   40   TV and Display (TVP)
KP51WS510    ALL    ALL    PITT   6/1/2003   RA6A   40   TV and Display (TVP)
KP51WS520    ALL    ALL    PITT   7/1/2004   AX1X   40   TV and Display (TVP)
KP57WS500    ALL    ALL    PITT   8/1/2002   RA6   40   TV and Display (TVP)
KP57WS510    ALL    ALL    PITT   6/1/2003   RA6A   40   TV and Display (TVP)
KP57WS520    ALL    ALL    PITT   7/1/2004   AX1X   40   TV and Display (TVP)
KP57WV600    ALL    ALL    PITT   6/1/2002   DA4X   40   TV and Display (TVP)
KP57WV700    ALL    ALL    PITT   6/1/2002   DA4X   40   TV and Display (TVP)
KP65WS500    ALL    ALL    PITT   8/1/2002   RA6   40   TV and Display (TVP)
KP65WS510    ALL    ALL    PITT   6/1/2003   RA6A   40   TV and Display (TVP)
KP65WV600    ALL    ALL    PITT   6/1/2002   DA4X   40   TV and Display (TVP)
KP65WV700    ALL    ALL    PITT   6/1/2002   DA4X   40   TV and Display (TVP)
KV30HS510    ALL    ALL    STE   8/1/2003   DA4   40   TV and Display (TVP)
KV30XBR910    ALL    ALL    STE   8/1/2003   DA4   40   TV and Display (TVP)
KV32HS500    ALL    ALL    STE   4/1/2002   DA4   40   TV and Display (TVP)
KV32HS510    ALL    ALL    STE   3/1/2003   DA4   40   TV and Display (TVP)
KV34HS510    ALL    ALL    STE   3/1/2003   DA4   40   TV and Display (TVP)
KV34XBR800    ALL    ALL    PITT   4/1/2002   DA4   40   TV and Display (TVP)
KV34XBR910    ALL    ALL    STE   8/1/2003   DA4   40   TV and Display (TVP)
KV36HS500    ALL    ALL    PITT   4/1/2002   DA4   40   TV and Display (TVP)
KV36HS510    ALL    ALL    PITT   3/1/2003   DA4   40   TV and Display (TVP)
KV36XBR800    ALL    ALL    PITT   4/1/2002   DA4   40   TV and Display (TVP)
KV40XBR800    ALL    ALL    PITT   4/1/2002   DA4   40   TV and Display (TVP)
