Автор Тема: E31755836  (Прочитано 725 раз)
E31755836
« : 07 Сентября 2016, 15:34:55 »
E31755836
Event ID
E31755836   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
8/14/2006 6:51:04 PM
Subject
No audio
No audio.
Sometimes if you change channels the audio comes back for a short time.
[Primary Symptom Code: 1510 ]
Solution
Replaced the AL Board.
Model Details
KDLV26XBR1    SEE    SOLUTION    STE      MIX5   40   TV and Display (TVP)
KDLV32XBR1    SEE    SOLUTION    STE      MIX5   40   TV and Display (TVP)
KDLV40XBR1    8013786    8013786    STE   2/1/2006   MIX5   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1147794A    504   AL Board KDLV40XBR1 ONLY   1511   APD   AL    A   A
