Автор Тема: E31754702  (Прочитано 691 раз)
E31754702
« : 07 Сентября 2016, 15:34:16 »
E31754702
Event ID
E31754702   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
8/15/2006 2:59:20 PM
Subject
CN6200 no wire on pin 11
No wire on CN6200/pin 11.
[Primary Symptom Code: 1311 ]
Solution
Found the G2 Board connector CN6200/pin 11 had no wire going to it.
This is supposed to be the unregulated 33v for the tuner.
I asked the digital module group they said that the 33v voltage is actually produced by the
tuner itself. Therefore the wire is no longer need.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Model Details
KDL40S2000    7023132    7023132    INY         40   TV and Display (TVP)
