Автор Тема: E31346481  (Прочитано 756 раз)
E31346481
« : 07 Сентября 2016, 15:31:55 »
E31346481
Event ID
E31346481   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
6/28/2006 3:01:24 PM
Subject
Colored vertical lines.
colored vertical lines, at cold start.
See picture of symptom below.
[Primary Symptom Code: 133X ]
Solution
Replacing the QM Board resolved the symptom.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Supporting Documents
File   Description
symptom.jpg   Symptom
Model Details
KDLV26XBR1    SEE    SOLUTION    INY   12/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    7001425    7001425    INY   12/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    SEE    SOLUTION    INY   12/1/2005   MIX5   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1147800A    155   QM Board   133X   DPR   QM    A   A
