Автор Тема: E31306863  (Прочитано 759 раз)
E31306863
« : 07 Сентября 2016, 15:30:51 »
E31306863
Event ID
E31306863   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
6/23/2006 1:42:46 PM
Subject
Solarized Picture
Solarized Picture
[Primary Symptom Code: 132X ]
Solution
Cleaned all cable connections between the QM and B Boards.
CN4801, CN4802, and CN4803 on the B Board.
CN7315, CN7316, and CN7317 on the QM Board.
This resolved the symptom.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Supporting Documents
File   Description
cables.pdf   Cables
Model Details
KDLV26XBR1    8025147    8025147    STE   12/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    SEE    SOLUTION    STE   12/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    SEE    SOLUTION    STE   12/1/2005   MIX5   40   TV and Display (TVP)
