Автор Тема: E31188492  (Прочитано 692 раз)
E31188492
« : 07 Сентября 2016, 15:27:56 »
E31188492
Event ID
E31188492   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
9/10/2007 5:38:00 PM
Subject
Picture on only half of the screen, another half is bright white.
Only 1/2 the screen has picture, another half is bright white.
See Symptom below.
[Primary Symptom Code: 1327 ]
Solution
Found T flex connector to The T-CON board came off.
Notes:
The P/N listed for boards, or components COULD be based on the sets model and/or
serial number.
Supporting Documents
File   Description
symptom.jpg   Picture of symptom
Connector.jpg   Connector
Model Details
KDL46S2000    7000496    7000496    INY   4/1/2006   WAX2   40   TV and Display (TVP)
