Автор Тема: E31146426  (Прочитано 650 раз)
E31146426
« : 07 Сентября 2016, 15:27:07 »
E31146426
Event ID
E31146426   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
3/12/2007 7:30:06 PM
Subject
Broken Connectors BU Board
Technicians are returning boards to Sony with broken connectors.
[Primary Symptom Code: 1111 ]
Solution
Please note, if a board or assembly is returned to Sony with damage due to the technicians mishandling Sony reserves the right to withhold all or part of the CORE charge associated with the part. See attached for pictures.
Supporting Documents
File   Description
Examples_of_broken_connectors.pdf   Broken connectors on BU board
Model Details
KDL23S2000    ALL    ALL    INY      WAX2   40   TV and Display (TVP)
KDL23S2010    ALL    ALL    INY      WAX2   40   TV and Display (TVP)
KDL26S2000    ALL    ALL    INY   2/1/2006   WAX2   40   TV and Display (TVP)
KDL26S2010    ALL    ALL    INY      WAX2   40   TV and Display (TVP)
KDL26S20L1    ALL    ALL    INY      WAX2   40   TV and Display (TVP)
KDL32S2000    ALL    ALL    INY   2/1/2006   WAX2   40   TV and Display (TVP)
KDL32S2010    ALL    ALL    INY      WAX2   40   TV and Display (TVP)
KDL32S20L1    ALL    ALL    INY      WAX2   40   TV and Display (TVP)
KDL32S2400    ALL    ALL    INY      WAX2   40   TV and Display (TVP)
KDL40S2000    ALL    ALL    INY   2/1/2006   WAX2   40   TV and Display (TVP)
KDL40S2010    ALL    ALL    INY      WAX2   40   TV and Display (TVP)
KDL40S20L1    ALL    ALL    INY      WAX2   40   TV and Display (TVP)
KDL40S2400    ALL    ALL    INY      WAX2   40   TV and Display (TVP)
KDLV32XBR2    ALL    ALL    INY      WAX2   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
VARIOUS    BU BOARD   Conn   1111   IMG   1111    D   A
