Автор Тема: E31124742  (Прочитано 690 раз)
E31124742
« : 07 Сентября 2016, 15:26:19 »
E31124742
Event ID
E31124742   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
5/31/2006 1:29:39 PM
Subject
Buttons not working
Buttons not working.
[Primary Symptom Code: 117X ]
Solution
Found CN7000 on the H6 Board loose.
The other end goes to the AL Board CN8202.
Notes:
The P/N listed for boards, or components COULD be based on the sets model and/or serial number.
Supporting Documents
File   Description
CN7000.JPG   CN7000
Model Details
KDLV26XBR1    SEE    SOLUTION    STE   12/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    SEE    SOLUTION    STE   12/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    8106503    8106503    STE   12/1/2005   MIX5   40   TV and Display (TVP)
