Автор Тема: E30808170  (Прочитано 704 раз)
E30808170
« : 07 Сентября 2016, 15:15:29 »
E30808170
Event ID
E30808170   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
6/28/2006 7:07:34 PM
Subject
StandBy LED does not light when TV is in stand by mode
While the TV is in Stand-By the stand by LED on the front of the TV is not lit yet the owners manual states that it should be.
[Primary Symptom Code: 1111 ]
Solution
The Owners manual is incorrect. The Stand By LED is NOT suppose to be lit while the TV
is in Stand By. This was changed on most models starting in 2005 as customers did not like
the stand by LED lit while the TV was off especially when the TV was in a dark room (ex bedroom).
Model Details
KDLV26XBR1    SEE    SOLUTION    STE   6/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    SEE    SOLUTION    STE   6/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    SEE    SOLUTION    STE   6/1/2005   MIX5   40   TV and Display (TVP)
