Автор Тема: E30658557  (Прочитано 817 раз)
E30658557
« : 07 Сентября 2016, 15:14:38 »
E30658557
Event ID
E30658557   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
3/31/2006 5:02:52 PM
Subject
Transparent white line at bottom of screen
Transparent white line at bottom of screen.
After 20 to 30 minutes, a 1 inch white line appears at the bottom of the picture.
Video info appears behind the white line, but color is muted.
Occurs with all inputs and PIP.
After 2 hours there would be black lines and pattern of vertical squares would be riding at the bottom of the 1 inch white line.
[Primary Symptom Code: 133X ]
Solution
Found DIC2 Board inside the MRU box.
Note: This is a TIP one technician found this on the set they were working
on. This does not mean the set you are working on will have the same solution.
The P/N on boards could be based on the sets model and serial number.
Please refer to the S/M for any serial number based P/N.
Model Details
KDL32XBR950    2004183    2004183    INY   8/1/2005   MR2   40   TV and Display (TVP)
KDL42XBR950    SEE    SM    INY   8/1/2005   MR2   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
A1302793A    355   DIC2 Board   133X   DPR   DIC2    A   A
