Автор Тема: E30540978  (Прочитано 681 раз)
E30540978
« : 07 Сентября 2016, 15:13:47 »
E30540978
Event ID
E30540978   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
3/17/2006 6:16:38 PM
Subject
Cuts out when changing channels, Q8214
Cuts out when changing channels.
[Primary Symptom Code: 2111 ]
Solution
Found Q8214 defective on the AL Board.
Model Details
KDLV26XBR1    ALL    ALL    STE   10/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    8030397    8030397    STE   12/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    ALL    ALL    STE   12/1/2005   MIX5   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
655054901    Q8214   DTC114EUA   2111   SYS   AL    A   A
