Автор Тема: E30412949  (Прочитано 660 раз)
E30412949
« : 07 Сентября 2016, 15:12:55 »
E30412949
Event ID
E30412949   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
8/28/2007 5:51:32 PM
Subject
Fuzzy or intermittent RF picture, Ant switch
Fuzzy or intermittent RF picture.
[Primary Symptom Code: 1341 ]
Solution
1. Fuzzy or intermittent RF picture
Replaced defective Antenna Switch.
2. Poor RF, No picture snow.
Replaced Ant switch no improvement.
Found QT Board was not allowing the RF switch to operate correctly.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Model Details
KDLV26XBR1    SEE    SOLUTION    STE   9/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    SEE    SOLUTION    STE   9/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    8049595    8049595    STE   9/1/2005   MIX5   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
859750400    115   Antenna Switch   1341   INP   NONE    A   A
