Автор Тема: E30362277  (Прочитано 738 раз)
E30362277
« : 07 Сентября 2016, 15:00:34 »
E30362277
Event ID
E30362277   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
8/9/2006 4:27:03 PM
Subject
Shutdown 9 Blinks, poor cold start C6727
Try to turn TV on and it shutsdown and the StandBy LED flashes 9 blink intervals.
[Primary Symptom Code: 118X ]
Solution
During cold conditions the TV may not start.
We made a change to the GI1 board to improve the cold start condition.
Replace C6727 on the GI1 board with part number 1-107-875-91 (220uF 10V).
NOTE: This cap is located on the A side of the board toward the top (see pics below)
Supporting Documents
File   Description
C6727.pdf   Pics
Model Details
KDLV32XBR1    7000001    7022400    INY   9/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    8000001    8018847    STE   9/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    8500001    8502697    STE   9/1/2005   MIX5   40   TV and Display (TVP)
