Автор Тема: E30003631  (Прочитано 717 раз)
E30003631
« : 07 Сентября 2016, 14:59:34 »
E30003631
Event ID
E30003631   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
6/28/2006 7:12:48 PM
Subject
No sound and AUDIO menu is grayed out
I have no sound through my speakers and when I try to access my Audio menu everything is
grayed out.
[Primary Symptom Code: 118X ]
Solution
Check CN7060 (H8 board) to CN8700 (AL Board) as the headphone detect line is located on pin1 and if this connection is missing you will get no sound and no audio menu. Reseat connector and check head phone jack for damage.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Model Details
KDLV26XBR1    SEE    SOLUTION    INY   6/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    SEE    SOLUTION    INY   6/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    SEE    SOLUTION    INY   6/1/2005   MIX5   40   TV and Display (TVP)
E30015999
Event ID
E30015999   Type
4   Safety Issue
No   AutoFlag
No   Last Update
6/28/2006 7:10:46 PM
Subject
No audio through speakers and Audio menu appears grayed out
I have no audio and my audio menu is grayed out.
Solution
Verify that CN7060 (H8 board) to CN8700 (AL Board) is seated correctly. This harness has
the Head Phone detect line and if the harness is not connected properly the audio menu
will be grayed out and you will have no audio through the speakers. With the harness disconnected the TV thinks that headphones have been plugged in thus disabling the
speakers and all but the MTS option within the Audio menu.
Notes:
Model Details
KDLV40XBR1    ALL    ALL    INY   6/1/2005   MIX5   40   TV and Display (TVP)
