Автор Тема: E29998533  (Прочитано 657 раз)
E29998533
« : 07 Сентября 2016, 14:46:08 »
E29998533
Event ID
E29998533   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
6/28/2006 7:13:41 PM
Subject
Dead, CN5001 to CN9101 loose
Dead.
[Primary Symptom Code: 2111 ]
Solution
Found CN5001 on the AL Board was loose.
CN5001 also connects to the B Board CN9101.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Supporting Documents
File   Description
CN5001.JPG   CN5001
Model Details
KDLV26XBR1    SEE    SOLUTION    STE   9/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    SEE    SOLUTION    STE   9/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    8026511    8026511    STE   9/1/2005   MIX5   40   TV and Display (TVP)
