Автор Тема: E29974703  (Прочитано 910 раз)
E29974703
« : 07 Сентября 2016, 14:45:10 »
E29974703
Event ID
E29974703   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
1/15/2010 7:45:53 PM
Subject
Unable to Power On or Off the set
The symptom may occur while the TV is ON or in Standby.
1) If the problem occurs while the TV is in Standby:
The TV will not turn on via the remote or power button located on the set however after AC reset (i.e. unplug the TV for at least 30 seconds from the AC source) the TV returns to normal operation.
2) If the problem occurs while the TV is in use:
You may lose the ability to power off the TV or switch the video inputs however channel changing, adjusting volume, or accessing the menu may still be possible. After AC reset (i.e. unplug the TV for at least 30 seconds from the AC source) the TV returns to normal operation.
[Primary Symptom Code: 118X ]
Solution
NOTE: The upgrade for the Sony Bravia models will be performed by the end user (consumer) only. Should an authorized servicer perform the upgrade, there will be no reimbursement paid.
NOTE: If you are a dealer using the BV100SU please see attached Bravia_Update_BV100SU.pdf. ALL others shall use Bravia_Web_Bulletin.pdf.
Serial Numbers:
NOTE: Not all units within this range are affected. Please see attached exceptions list or have the customer visit http://www.updatemytv.com to verify if their unit needs an update.
The warranty for this symptom has been extended to June 30, 2009
26XBR1:
7000001___to___7013200
8000001___to___8007573
8500001___to___8501034
32XBR1:
7000001___to___7022400
8000001___to___8007500
8500001___to___8501201
40XBR1:
7000001___to___7022500
8000001___to___8016145
8500001___to___8502475
Sony has designed the BRAVIA Televisions to be CUSTOMER Software Upgradeable and therefore Sony will not pay a service claim on any issue resolved by a software upgrade. If a customer requests an update please refer them to the following website: http://www.updatemytv.com. If the unit requires the update, you may enter the customer's information in the website and a USB device will be sent to their address.
If a customer does not have access to the web please have them call the Sony Call Center Support line: 1-866-210-6333
If a customer reports either symptom above request that they unplug the set from the AC wall outlet for at least 30 seconds and then plug the set back in. This will reset the TV and it should work fine for several months. If resetting the TV does not resolve the issue the customer has a different problem and a service call by a technician may be required.
Supporting Documents
File   Description
USB_ROOT.zip   SOFTWARE DOWNLOAD BV300UU
Bravia_Web_Bulletin.pdf   Service_Bulletin
Bravia_Update_BV100SU.pdf   Service_Bulletin_for_BV100SU
Model Details
KDLV26XBR1    7000001    7013200    INY   6/1/2005   MIX5   40   TV and Display (TVP)
KDLV26XBR1    8000001    8007573    INY   6/1/2005   MIX5   40   TV and Display (TVP)
KDLV26XBR1    8500001    8501034    INY   6/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    7000001    7022400    INY   6/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    8000001    8007500    INY   6/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    8500001    8501201    INY   6/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    7000001    7022500    INY   6/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    8000001    8016145    INY   6/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    8500001    8502475    INY   6/1/2005   MIX5   40   TV and Display (TVP)
